- 7 Aug 2004
As title, whats a good bang for buck one ? less than £100 ideally, however must support both mac and pc and support 2 monitors (HP h-ips and dell 2407)
I just got a spider 3 Elite... admittedly that was near £150. I can't say a bad word against it. All of the Spyders are PC and Mac compatible. The Pro and Elite models both do multi monitor.
I chose an Eye1 based on the reviews.
I paid £104 for it.
which version ? there seem to be a couple, do they all support multi monitor ?
EDIT: Got hold of a new spyder 3 pro for £86, seems a good buy
Eye-1 display 2 by x-rite (it is the same hardware as the very expensive
La-cie GretagMacbeth thingy )
Not sure about multi-monitor support. Unless you have very expensive non-TN film monitors then you will always have issues with multi-monitors anyway.
Got the spyder 3 seems to work well accross my HP2475w and 2407
What made you go for the pro over the express model. I'm thinking of buying one myself soon and trying to see the benefits of the pro model over the express?
