Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
What should I get? I don't need a 990pro or the latest and fastest as it will be bottle necked.
Whatever is cheapest TBH. You might want to avoid QLC if you're likely to hit it with heavy writes.
What capacity are you looking at?
No many great deals around currently if you need to buy right now, high end at £100 ish is the Kingston Fury, total overkill but all you're going to save is £20 by going for a QLC drive like the WD Green SN350 or Crucial P3.
You mean a Crucial P3 and WD Black if it's SN850? The Blue is the 580 I think.Would Crucial T3 be suitable for this? I think I bought this last time but returned it because the 990Pro is "better", but for this purpose, is the T3 suitable since I am bottlenecked by the enclosure.
Or WD Blue SN850?
The WD Blue is TLC and has twice the write endurance than the P3 Plus (which is QLC) so that would be my pick.Sorry, 580, not 860
Crucial P3 Plus SS
WD Blue SN580 2TB
You would need a 40gbs enclosure unless I'm mistaken for pcie4 speeds which one do you have or getting?i have the same requirement, and I have two rule:
1. techpowerup reviews for sustained writes (fill whole drive).
2. be considered to have low-power and good thermal.
anything that can sustain an average of 1.5GB/s for 2TB at storage at <8W is a winner.
SK hynix Platinum P41 2 TB Review - Faster than Samsung and WD
The SK Hynix P41 offers amazing performance thanks to a new PCI-Express 4.0 compatible controller. In our Hynix Platinum P41 review we find that this drive is faster than Samsung 980 Pro and WD Black SN850. Thanks to an energy efficient design, there is no thermal throttling, even without heatsink.www.techpowerup.com
the OWC Express 1M2 has reviewed quite well.You would need a 40gbs enclosure unless I'm mistaken for pcie4 speeds which one do you have or getting?
Those 2 criteria don't apply to me.
1 - it will never write constantly from o to 100% full to the brim in 1 sitting.
2 - It won't be plugged in 24/7, will likely be sitting in my travel tech pack.
What you are looking for seems to be for desktop use and I question the first point....what is it that you do that need to sustain writing 2TB size files, everyday constantly, then delete and go again, and delete and go again and delete and go again?
