What opteron should i get?
11 Apr 2006
lo,
I have a opteron 148 2.2 currently the cabbage version and it overclocks to about 2.7ghz. However im looking to build a second system and this chip would be going in the second one. I will be looking for a new cpu and wanted to stick with opteron ideally, dont really want to wait for conroe.
What opteron can you suggest?
It will be cooled via Zalman water cooler.
Using gskill 2gb ram
x1900xt 512mb.
Thanks.
BTW: Im looking to spend around 350 on cpu and mobo, maybe a little less.
Whatever you can recommend?
Ideally i wanted to stay away from DFI, the 2 ultra-d's ive had: both the chipset fans failed within a month, one came with a fault bios chip and nothing would boot.
However, if DFI is the best option then thats what ill go for.
My gfx card is a x1900xt 512mb pci-e, wont be running in crossfire.
Well you will need a good board if you get the 165 due to the 9 multi, anything over 2.7 will need a board than can do 300HTT. The 170 is the safer bet if the boards not great.
AMD Opteron UP 170 Dual Core San Diego 2.0GHz 2MB Cache (Socket 939) - Retail (CP-148-AM)
£249.95 £249.95
MB-088-AS Asus A8N-E nForce4 Ultra (Socket 939) PCI-Express Motherboard (MB-088-AS)
£54.60 £54.60
Subtotal £304.55
VAT £53.30
Total £357.85
I would pay the extra for the 10x multi on the 170 over the 165
easyrider said:
I would pay the extra for a DFI mobo
I wouldn't! I've found them to be far to fiddly in terms of finding the most stable options. I've got an asus and with the higher multi opterons they do fine.
Thats what overclocking is about !
And you WILL NOT get a more stable mobo than a DFI
In a league of their own. :D
