Hard to say without looking at it from the end but just looks like a figure 8 connector. Probably officially has a different name but searching that brings them up
Cheers guys! That's exactly what it is, yeah was looking for the actual type to search for (looks like it's an IEC C7 connector), but figure 8 brings them up.
Just to check, are you sure you need a new cable? If the original isn't working, it might be that the fuse has blown. If it's that, you could change the fuse, or change the whole plug including fuse.
