What power supply?
21 Aug 2009
Sheffield
Hi guys,
I am in need of a new psu and my current specs are
AMD Athlon 64 5600+ x2 am2
Abit A-N68SV (requires EPS12V)
8800 GT
4GB Kingston HyperX PC2-6400
One SATA HDD
Three 120mm case fans
Zalman cpu cooler
Can anyone suggest a decent psu for my needs as I dont want to invest in an expensive supply which isnt needed.
Im sure others will give advice on particular models, but bare something in mind -
PSU's are something that you could keep for a number of years, so it is worth getting something decent, as it could stay with you for 3 or 4 builds, maybe more, depending on how often you upgrade.
Hi,
I had an almost identical spec rig & I used a 500w with it for ages with no problems. I upgraded to 850w as i intended to build a bad boy SLI rig but never did so it was a bit of a waste.
I've just bought a Corsair TX 650w following people's advice from this forum. I would say don't spend loads of money on loads of W's unless you need it & make sure you buy a decent make.
Row_bot
