Caporegime
- 8 Jul 2003
- In a house
I've always done the same - bought quality PSU's. Then my 550W Enermax blew up and nuked my mobo and CPU. You can only do so much! Mind you I'm back (and happy) with an Enermax 600W after a year with a "ticking Tagan"...!Cashman said:I agree with Loadsamoney on the PSU front... it's the one component I have never skimped on after seeing a PC go "boom".
I have always had a very good PSU and have been happy in the knowledge that it will never hold my system back and any problems are likely to be other factors...
I say, stump up the extra £30 and always get a PSU that costs closer to a ton.
I promise you will always feel happy with your choice!!![]()
Credo said:I've always done the same - bought quality PSU's. Then my 550W Enermax blew up and nuked my mobo and CPU. You can only do so much! Mind you I'm back (and happy) with an Enermax 600W after a year with a "ticking Tagan"...!
LoadsaMoney said:Bit of a bad reputation the Hipers, they've been going boom as of late.
Cartho said:500 watt is the bare minimum
SOLDNER-MOFO64 said:Not saying its ideal, but I've run an ASUS M2N-E, an AM2 X2-3800 @ 2500mhz, 2GB [email protected] HD....a DVD drive and an ASUS EN8800GTS all from a single 400w PSU with 14amp on 12v rail.
Never had a single problem![]()
dale1uk said:Only problem with that is when the psu goes pop is a lottery of what it will take with it. You might be lucky and its only the psu that dies, but if it takes out your whole rig then your talking big bucks to replace everything.
Why do people risk a £600+ rigs with cheap under powered psu that will go pop at some point and possibly take out their whole pc![]()
