What PSU for media server with 6w tdp CPU?
11 Mar 2012
North East
Hi all,
I have a small pc i use for Plex and to store documents. Spec:
Bitfenix colossus itx case
1 x Samsung ssd
1x 2tb had (should maybe replace its ancient and has broke before!)
Biostar J3060 on board deletion
4gb so-dimm (that’s what it takes)
my old psu was a 550w coolermaster I think, i was testing it in a friends pc pre lockdown,as theey had a suspected faulty psu.
thought I’d be without it a week! Anyway until I eventually get it back....
is this ok:
https://www.overclockers.co.uk/kolink-core-series-300w-80-plus-certified-power-supply-ca-02l-kk.html
Also considered
https://www.overclockers.co.uk/kolink-kl-500-500w-80-plus-bronze-power-supply-ca-011-kk.html
I know psus are most effective at a certain draw I’m just not sure what power the system uses. Very low I suspect. With getting my psu back eventually I don’t want to spend lots. (Yes I know the issues you can get wit cheap psus, hence asking)
TLDR:
Cheap psu recommendation for low power media server.
thanks all!
If you want a cheap PSU, get a used FSP unit from ebay as the 300 or so watt units go for around £10-20 depending on the form factor (budget builds on youtube recommends them over the tat like what you've linked to)
Thanks! that confirmed my suspicion on the cheapies, got a FSP one, seen the small £8 ones but went for a slightly bigger unit, think it was 300 watt for around £15. Installed everything running and very very quiet.
Happy! thanks for the advice. Also that budget builds is good!
