Thanks for the reply. I'm on a bit of a budget so would be looking at something cheaper than that.
The OcUK Swift 650W would be more my price range.
Would I be better buying second hand?
All the 500w are out of my price range brand new.
There is only this 450w but not sure if that will be sufficient.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-238-CM
I intend on selling the 260GTX for a 460 as per your recommendation in my other thread.
Thats ok then, if the GTX460 was that B grade item then also get a MOLEX-PCI-E power adapter.
http://www.overclockers.co.uk/showproduct.php?prodid=CB-033-OK&groupid=1929&catid=153&subcat=
Just in case it doesnt come with one.
If he's buying a PSU, why would he need it![]()
The GX450 PSU has a single 6pin PCI-E connector, a GTX460 card needs two like the GTX260.
The GTX260 he has would have come with a molex adapter (assuming it was complete and new) , but if he sells it on then he may like to include this also.
