What PSU?
29 Aug 2010
United Kingdom
Hi guys,
So almost ready to build a small HTPC. using a phenom X3 and an Asus M4N68T-M, with atleast 2 HDD's a DVD drive and a Saphire low profile 5770
What PSU should I get for it?
Thanks!
Rob
I would have thought that that's a bit much for a PicoPSU to handle, so I'd get one of the Corsair Builder series if it was me.
I'm on a damned strict budget, Do you think a 250w will suffice, the setup will hardly be stressed at all, streaming to one source, Where can I get a be quiet SFX 300w? and how much?
I have dude =/ I've looked on the fleebay, the rainforest in africa, and various other sites, All I can find are CiT psu's that are rated very poorly by reviewers due to them being noisy, however at 20 quid they may not be too bad for the price, who knows.
I think I'll stick with the built in 250w in the case as £50 is abit out of budget, I was thinking more along the lines of 20-30.
Is it possible to damage components with too low a PSU?
Spending so little on a power supply... well i guess it's ok if the computer is worth little. But i would never do it mate
If it was for my i5 then £100 or more,
This is supposed to be a really low power build with little cost so it doesn't matter so much,
@chippy08 really? hmm.. i'll stick with the 250 it comes with and if it needs more i'll have to do some research or just get a case that fits ATX psu's
Cant you use a 5450 or something instead of a 5770? If its only for a htpc, itd be using nearly 100w less.
