What router do i need?
6 Oct 2004
England
Hey, im looking for my first router.
At the moment i just have modem to pc through a ethanet cable.
But i need to plug in a pc and xbox360, as well as a wireless laptop, so not sure which is the best/cheapest to get?
Thanks
If it's NTL, it's highly unlikely to be ADSL (unless it's a resold setup through someone like Virgin.net), and you wouldn't get a modem with an ethernet connection free.
I'd suggest checking for sure...
ohh proberly cable then :o
How do i tell? All i know that it is the NTL2mb connection, it connects via ethanet from modem to PC
Look at the modem for starters, if you quote the make/model number (that'll likely be printed on it), someone should know.
So you're looking for a "cable/DSL" router, ie one which doesn't have a modem.
Linksys WRT54G (lobotomised)/GS (Speedbooster)/GL (v4 G, will run all the 3rd party firmware floating around) is a well liked suggestion.
Thanks ill take alook, also i forgot the mention that the laptop has a d-link wireless card, cant remember the model right now as a family member has taken it to the libary
As long as it does 802.11b (11Mbps) /802.11g (54Mbps), it'll be fine. I used my WRT54GS with a 3Com card with no problems.
Speedbooster would be a waste of time though.
Cheers.
How would it work then?
I plug my computer xbox360 into the router ,and then the wireless works with the laptop?
