hi to all. im looking into building my 1st system. this will be my 1st ever build. i have been reading over some guides on here, pointers and other sections of this forum and have found loads of advice, tips, terminology etc etc. i recentley took apart my current computer, cleaned it and put it all back togeather and though....I WANT TO BUILD ONE FROM SCRATCH.
Anyway to the point of this thread:
im after building a system. now i was thinking of buying cheap parts to build a cheapo. but i wanted to look at overclocking down the line so i keep getting drawn to the i5, i7 systems but there are so many motherboards, must i cant really see much difference e.g:
http://www.overclockers.co.uk/showproduct.php?prodid=MB-320-AS
and this:
the one immediatley a bove has 'SE' in the model code....can they be that different to justify £30?
anyway i have seen bundles from overclockers, ebay and various other sites to get you started. e.g CPU, motherboard and some RAM. and have even seem some 'what look like' good deals at a computer fair.
basically i dont know if i should build a cheapo or go to town with an i5/i7 system.
any thoughts...
and this:
any thoughts...
