Hi all,
I had an Antec Phantom 350watt fanless psu installed until yesterday. It's been in 11 months and all has been OK up until now. Yesterday the PC woudn't start up - I pushed the power-on button and the PC burst into life and then died within a second.
It was workng perfectly OK before I shut it down hours before. It normally runs at least 12 hrs /day and quite often 24/7.
I still had the old psu - a Q-Tec 350 watt quiet unit - so I swapped it back. PC started up perfectly Ok. Then swapped Antec back - wouldn't start. Put Q-Tec in - OK. So it seems the Antec has devloped a fault which makes it shut down.
Question - is there one of the cables that senses some voltage that makes it shutdown? Is there any adjustment. Have sent an RMA request to Antec - just wondered if anybody else had the same problem?
Mel_P
Mel_P
