What size power supply for this spec ?
Again i appreciate the suggestions.
If that were me i would be thinking the same as you to match up the colours of the components of the hardware, my mate isn't bothered about that as he is just interested in getting a faster PC than the older one he has now. On that powercolour card you could always take the side panels off if you wanted too as they are only held on by screws and respray them what colour you wanted, that would probably invalidate the warranty tho.
I'm basically going with your GPU the Powercolour, the 4670K CPU, sniper M5 motherboard, 350D case, the 140mm AF fans, the power supply you suggested.
Only things ive changed are the memory and the cooler
Going with this memory to match the board
http://www.overclockers.co.uk/showproduct.php?prodid=MY-044-AR&groupid=701&catid=8
And this Air cooler, i have the bigger version PH-TC14PE myself and its been great.
http://www.overclockers.co.uk/showproduct.php?prodid=HS-012-PT
