- 27 Apr 2018
Hey all,
I currently have the following setup:
Watercool Heatkiller IV CPU Block
Watercool Heatkiller 1080TI Block
Hardware Labs Black Ice 280MM
Hardware Labs Black Ice 140mm
XSPC Photon 270 with X4 Pump
Thermaltake Core P5
So I am looking at purchasing the above case from overclockers:
https://www.overclockers.co.uk/lian-li-pc-o11-dynamic-midi-tower-black-window-ca-76s-ll.html
I am wanting to fit a 360 rad in the back / vertically, and one down bottom underneath the GPU with 120mm fans, while also mounting the XSPC photon on the vertically stacked radiator, how ever I have read about limitations on fan and radiator sizes in this case, could anyone please provide some guidance, I would ideally like this to be as quiet as possible with low rpm fans, while also providing good temps. What radiators would you guys recommend?
Additionally I have read that some GPU's can not be mounted horizontally with full cover blocks due to clearance issues, does anyone know if the heatkiller block will fit? I prefer it to horizontal layouts.
Thanks!
Thermaltake Core P5
Thanks!
