Poll: What speed connection do you use?
What speed internet connection do you have?
  • Dial up
  • Less than 1Mbps
  • 1Mbps or above but less than 2Mbps
  • 2Mbps or above but less than 4Mbps
  • 4Mbps or above but less than 8Mbps
  • 8Mbps or above but less than 50mbit
  • 50Mbit - 100Mbit
  • 200Mbit - 330Mbit
  • 330Mbit - 500Mbit
  • 500Mbit - 1Gbit
Results are only viewable after voting.
Before - ADSL and frequent disconnects
After -
Hope it gets closer to the 80/20 I'm paying for as I'm less than 100metres from the cabinet, but it's only been a few days and at least so far its stable which i couldn't say about the adsl.
You won't get 80/20 exactly - there is some overhead between the sync speed and the actual data throughput - some of the BT devices have upstream QoS by default that prevent you getting quite the full upload speed in tests not sure if you are using such a device. Maximum data download rate is about 76MBit/s. You might get the upload to 19MBit/s with a bit of luck.
Hyperoptic in central London. It turns out that a ping of under 1ms reports as 0ms:
I used to ping 1-2ms to London datacentres on the 150Mbps service but it has dropped to below 1ms on 1Gbps - must be some internal routing thing for the restricted/lower tiers that was causing all of that awful extra lag.
Recently had the 'you're prices are changing' letter from BT so decided to see if I could re-negotiate to the same or slightly lower price - I was on the BT Infinity 4 package at 330/30 (realistically 300/30) and so swapped over to one of their BT plus packages for slightly less than what I was currently paying on the Infinity 4 package. This new BT plus is suppose to be 330/50 - can't say no to more upload speed right?
Got switched over during the day and came home to find the faster upload - overall very pleased with the speeds!
