Flanno said:
Thanks for the info. Cheers.
Btw, what is the best air cooling solution for this cpu ?
Depends on the case/airflow really. I have a Thermalright XP90C (pure copper) + 92mm silent fan and since changing mobos to a i955x it is only enough to keep my 670J cool. Got a Zalman 9500 coming later today as my case layout needs something like that to blow the hot air out the exhaust slots immediately.
As the 955XE runs almost as hot as the 670J would say go for either:
ThermalRight SI-120 (Socket 754/939/478) Heatsink (HS-023-TR)
Price: £26.95 (£31.67 Including VAT at 17.5%) Plus you also need to buy an LGA775 fixing kit (OCUK no longer stock it) & 120mm fan seperately.
Gigabyte G-Power Pro (Socket A/754/939/478/775) Cooler (GH-PDU21-MF) (HS-004-GI) Price: £24.95 (£29.32 Including VAT at 17.5%)
Good cooler but supposed to be very noisy @ high speed. Seen 72db quoted for it!
Zalman CNPS9500-LED Aero Flower (Socket 939/754/478/775) CPU Cooler (HS-015-ZA) Price: £31.95 (£37.54 Including VAT at 17.5%)
This is the one I get today. Did a lot of research on it beforehand. Some people say it is very noisy whilst others say silent. Must depend on your case configuration & ear distance to it.
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775) (HS-017-AR)
Price: £12.95 (£15.22 Including VAT at 17.5%)
Bit confused about this one as some people say it is a very bad performer if you have a hot cpu (like the 955xe/670j) whilst others say no problem @ all. I'm put off by the cheap price and small fan TBH.
Few more here but the ones I listed are the best P4 air coolers OCUK do @ present.
http://www.silentpcreview.com/article30-page1.html
A lot of it boils down to how much noise bothers you & how much money you wanna spend as going quiet can cost £300++. Consider that a 955XE needs a very good PSU (as do all PCs really). Lot of people buy cheapo ones which can have issues not supplying enough power. Decent one will be approx £100-120.
