What speed should I be able to get?
tolien said:
If the SNR margin was stable it would be attainable...
I would hazard a guess that this would mainly happen on short lines?
I don't know anyone on Max who has a stable connection on less than 3-4 dB SN/R so it must be quite rare.
Strange, just tried a netgear router and my stats are now:
ADSL Link Downstream
Connection Speed 576 kbps
Line Attenuation 49 db
Noise Margin 29 db
According to http://www.dslzoneuk.net/maxspeed.php
Based on the values you entered, we estimate that your line can support around 5.7 - 6.5 Mbps.
Well adsl max was switched on today. First results arent bad. Had a few disconnects though, is that normal?
TiZoR said:
yeah keep an eye on them crc errors
and whats your router m8?
netgear DG834G
ADSL Link Downstream Upstream
Connection Speed 5376 kbps 448 kbps
Line Attenuation 53 db 15.5 db
Noise Margin 6 db 20 db
Its not quite so good now!!
Connection Speed 4864 kbps 448 kbps
Noise Margin 7 db 23 db
Is there anything I can do?
Just did it now and am getting
Connection Speed 4960 kbps 448 kbps
Noise Margin 6 db 21 db
Will test this evening
This simply calculator will estimate the maximum line speed that an ADSL line will obtain. It will only estimate up to speeds of 8192kbps. Once the performance of ADSL2+ becomes clearer, I will endeavour to incorporate those speeds also.
Is this true from that site? cause if it is im applying for an update from bt im only on 2mb
What site?
If you mean MrSaffron's calculator (the 212.23 etc) IP, then it's true enough - it'll only guesstimate up to the full 8Mbps that ADSL will do.
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 52628 67663 0 216 1322 13:21:38
WAN PPPoA 64688 83059 0 260 1537 14:18:27
hmmm cant even get on the speed tester at the moment. Pages are really slow etc.
Managed to get on the adslguide speed test and got:
Speed Test Results
Downstream 359.7 Kbps ( = 0.4 Mbps )
Upstream 55.5 Kbps ( = 0.1 Mbps )
I am still synced at 4960 kbps. Stats:
WAN PPPoA 284094 313670 0 1859 3013 14:56:22
LAN 10M/100M 670399 671774 0 3640 2557 25:28:28
WLAN 54M 585 0 0 5 0 04:05:48
Noise Margin 5 db 21 db
any ideas?
