what speed with these stats
1 Dec 2002
Swindon
Hi,
What kind of speeds should I be getting with this sort of numbers?
System Up Time 00:38:19
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 7874 11196 0 834 5111 00:35:24
LAN 10M/100M 10001 7340 0 4109 767 00:38:14
WLAN 11M/54M 3350 2418 0 1230 205 00:32:45
ADSL Link Downstream Upstream
Connection Speed 8096 kbps 448 kbps
Line Attenuation 35.0 db 21.5 db
Noise Margin 7.3 db 27.0 db
With that sync rate, you should expect to be on the 7Mbps IP profile - so about 850kB/s.
Your SNR margin et al are irrelevant - it's only what your modem's connected at that's important.
Just out of interest, if my exchange had ADSL2+ LLU (Be, etc), what kind of speed would I get with those stats? Is it possible to tell?
You'd get more than you get just now - probably a good bit more - with ADSL2+. Whether it's LLU or not doesn't matter.
There's an estimator in the sticky (which reckons ~14000kbps), but it's purely an estimate.
