What speeds should I expect from SATA hard-drive transfers?
Man of Honour
12 Jan 2003
UK
I have the following two hard drives in the same system, but wanted to sanity check what transfer speeds i should expect when copying and pasting content between the two:
Samsung 250GB 860 EVO SSD 2.5" SATA 6Gbps 64 Layer 3D V-NAND Solid State Drive (MZ-76E250B/EU) -
Western Digital Caviar Green 1TB SATA 6Gb/s 64MB Cache - OEM (WD10EZRX) **SINGLE PLATTER** HDD
When copying a 4Gb file from one to the other i'm getting speeds of about 120 MB/s, is there a way to improve this?
Bottle neck will be the slowest hard drive, not sure what you are expecting? Do you need someone to Google what speed the WD hdd transfers at?
That's about right for a smaller mech HDD. The only way to change it would be to change the mech drive to either a larger more modern mech drive or even better an SSD.
Your bottleneck isn't the bus, it's the mechanical drive.
thanks guys, i just wasn't sure if that was a reasonable transfer rate between those two. appreciate the replies
Single platter drive's data density should give more like 150 MB/s STR, but that of course drops if drive is more full.
But is that drive single platter one?
Manufacturers stopped giving out that information long time ago and that 120MB/s would fit well to earlier models:
http://usa1gary.blogspot.com/2015/09/western-digital-wd-green-wd10ezrx.html
