- 22 Oct 2004
- Berkland
Hi people,
Well basically I am getting rid of my desktop as I hardly ever play any games on it anymore, and I find myself using my work laptop to do all my home computing on. Now my desktop has a ton of junk on it that I want to keep and thus I need to look for a storage solution as the work laptop only has 40GB disk space.
Now should I be looking at a NAS drive or a USB drive? Im thinking I should really get a USB drive as they are more portable (like the laptop), plus maybe I should go for one of the ones that run off of the USB power. The only downside for this though is access speed. If I go for a USB portable drive (500GB one) will I see a performance hit than if I went for a drive with a power brick?
Plus, I really want to be able to run programs off of the disk as well (for example some of the older games that I have, or some of the portable apps that you can get).
Much help in making this choice is welcome!
Cheers all
Cheers all
