- 31 May 2006
- West London
@Jay Bee - passive watercooling breaks the rules of some of the water cooling data out there. So actually both you and Monkey Puzzle are right.
For what I can find and personal experance
Active cooling you should be aiming at optermal MIN .9-1gpm.
Flow rate is slightly more important that head (unless useing turbulance blocks)
Copper Rads work best (with force air flow)
High fin count = high fan rmp (performance)
Low fin count = low fan rmp (quiet)
Heat removed mostly by convection
Passive cooling you should be aiming for a optermal MAX of .9-1
head is more important that flow rate (low restriction block are slightly better)
Only low fin count 'standard' rads should be used.
Radient aluminum systems possable (but need large non-fin surface area)
Which Zalman system are you using Jay Bee, and have you tweeked it, as 40c for a quad is very impressive (I get that on my E6600 but it is a 5 block full loop)
Edit: thanks ecat - did it for the quiet, but fanless is a blessing and a curse
 . Pity I'm going to have to cover the copper really, as polished copper is an absolutely beautiful light salmon colour.
. Pity I'm going to have to cover the copper really, as polished copper is an absolutely beautiful light salmon colour. Maybe it's like mama always told me and pretty isn't always best ?
