I currently have upgraded to a Q6600 running at stock voltage with no overclocking.
Im using an Asus Silent Sqaure to cool this and my temps are around 50oC to 55oC idle and when using Orthos they go from 66oC to 75oC.
I called tech support at OCUK and they said it should be running at between 20oC and 30oC.
I dont know if that is the right temps for this chip as my C2D E6400 that I had running stock on idle was 33oC
Can you start putting up your Q6600 temps up so we can compare temps and also what Heatsink and fans you are using...
It would be nice to know what the average temperatures are...
Thanks Guys
Thanks Guys
