Food poisoning from bacillus cereus (most commonly found in rice) can definitely give you the runs within 3 hours actually. And can last anywhere between 6 and 24 hours.
Do you get that from unwashed rice or from just bad luck?
I doubt it was from the curry due to most pathogens needing around 24-48 hours to multiply
Better than making useless posts on a PC forum!Consult a PC forum.
Better than making useless posts on a PC forum!![]()
It can't be from unwashed rice as it gets cooked and there for kills the bacteria anyway.
just wondering who you would moan too, the store or escalate it?
Oh noes! I got flamed by beansprout.![]()
I've heard that reheating rice can cause food poisoning. Is this true?
It's true that you could get food poisoning from eating reheated rice. But it's not actually the reheating that's the problem – it's the way the rice has been stored before reheating.
Uncooked rice can contain spores of Bacillus cereus, bacteria that can cause food poisoning. When the rice is cooked, the spores can survive. Then, if the rice is left standing at room temperature, the spores will germinate into bacteria. These bacteria will multiply and may produce toxins (poisons) that cause vomiting or diarrhoea. Reheating the rice won't get rid of these toxins.
So, the longer cooked rice is left at room temperature, the more likely it is that bacteria, or the toxins they produce, could stop the rice being safe to eat.
It's best to serve rice when it has just been cooked. If that isn't possible, cool the rice as quickly as possible (ideally within one hour) and keep it in the fridge for no more than one day until reheating.
Remember that when you reheat any food, you should always check that it's piping hot all the way through, and avoid reheating more than once.
