What to do
23 Mar 2004
Up t'north
Im a complete n00b when it comes to RAM so here goes
Ive got 1.5gb RAM as in sig
Ive got a stick of 512mb @ 3200 and a 1gb Stick @ 2700.
Is the 1gb stick slowing the other stick down. Show i take it out. Or should i just get a 2gb Kit? If so what do you recommend, i dont want to pay over the odds with the holiday just around the corner!!!
Many thanks
-m-m-
The 1gb stick at 2700 wil cause the other stick to run at 2700 speed. Your best taking it out if you can get away with only 512mb ram. 2gb kit would be the best solution or even a 1gb kit as this will allow dual channel which adds about 10-15% performance to the system
I did a test when i came in today to see how much the 1gb was slowing the system down. I did a cold boot to accessing the start menu
with 1gb in it took 2mins 16
without it took 1min 40
Only problem with it out is how much i can multitask!
