Permabanned
- 15 Nov 2008
As title says, thinking about modding my case n want to check what tools I'd need
Was thinking of getting dremel 4000-4/65 and 114mm hole saw
Link
This says does not include arbor, which I get is the bit in the middle used for locating holes, but is there any particular type/size I need to get?
Was thinking this one???
Anything else I need to be looking at? Aside from file, masking tape, wd40, specs n gloves?
Also wanting to put cable routing holes in, with grommets a la corsair cases, only grommets I've managed to find are plain open circular ones, anyone know if it's possible to source ones more like the ones corsair use?
Many thanks
Link
Many thanks
