The EK 780ti fullcover block fits the standard 780.
http://www.coolingconfigurator.com/step1_complist?gpu_gpus=1046
Does it have to be plexi? The only full cover blocks I can find for that model are opaque.
Polish it up
it's not that hard, just a lot of elbow grease![]()
: I'll toot my own horn here,
But here's a guide type thing:
http://forums.overclockers.co.uk/showpost.php?p=27458910&postcount=66
Well The gasket I just pressed it in the groove and it held in while I re-positioned the top.
I was told to avoid a dremel, hand polish all the way.
Google: "lowfat polishing"
There's a guide elsewhere which I followed, very good results posted with it
polishing alone can get nice results
for a 'glass like' look you need to sand
Yeah. Its a bit of gathering supplies, I got it all from the rainforest.
Aaah bending, that's this weekend's chore. Wait.... I mean party?![]()
I'll probably do a similar thread walkthrough. But there's plenty already.
I wanted the same thing, parvum are gonna have their hands full when they release their atx.
I'm getting the paneling for my case done by them. Should be here this week![]()
God.
Never add up the cost of water cooling, and never tell your partner that figure![]()
Bitspower are a lovely brand with nice kit. And a hell of a markup. I like EK, they look good IMO especially the circles all polished
But really I couldn't bring myself to pay for their blocks, shipping alones enough
The backplate should fit, there's only so many holes, just check the 2 pieces use the same ones.
so bitspower the way to go if the price is right.
