what voltage are people using for 6700k ( any speed )
24 Aug 2015
Would also be interested in knowing max temps after a pretty heavy gaming session, I just want to see if my cpu temps and voltage are similar to everyone,
In bios all I changed was v core and disabled turbo boost,
vcore set at 1.152 everything else left the same,
after about 4 hours of gaming my temps are as follows
core 1 69
core 2 69
core 3 62
core 4 67
cooler h100i gtx
core 1 69
core 2 69
core 3 62
core 4 67
cooler h100i gtx
Which motherboard is it? Those temps are out of whack for 1.152 Vcore.
4.6ghz 1.3v here (stock voltage for my CPU).
Noctua UH12S, single 120mm fan, heavy gaming season 75-78c. Runs lovely and cool, blower GPU helps also.
Most importantly, it's completely silent :) I can do 4.7Ghz and 4.8Ghz with the fan cranked up and with more voltage, though prefer a cool and quiet system at 4.6 for 24/7 settings.
4.7ghz @ 1.384V running realbench gives me
core 1 62
core 2 63
core 3 59
core 4 60
Package 64
Thats with 2 x 240 rads
Are people getting spikes? I would on my 4.5 6700k at 1.325V. In Projects Cars with about 70% usuage get a steady 60 odd degrees there abouts through the game. But I would notice core temp would say something like 68 degrees on a core. I would carefully scan the line in AB and notice these spikes in loading for a second. This would mean core temp although would be correct but would not give you an accurate picture of your gaming temps, as it would say for a 2700k to use at a glance.
4.7 @ 1.344 gigabyte z170x gaming 7
max temp 62c with ixtu stress test and low fifties during gaming.
What have you adjusted? Do you know how to alter the load line Callibration? its on Auto, but the Manual does not say how to adjust it. I have tried putting in voltages, a single digit 1-5 ect, and even off, disabled. It just goes back to Auto when you save. The manual does not explain, what you should type in, overwrite just what its used for.
