Finding your first post
Go to search > advanced search
Search for posts by your username and order in ascending order.
Not sure if this has been done before but Just thought I'd just throw this out there and ask a simple question..... What was your first ever post?
I had to close a few Wanted threads earlier and thought I'd read my own introduction into the OcUK family. Had to smile at the rig I used to own, and what I bought at the time.
Here's mine dated 16th May 2007
*Hope this thread is in the right place....
Hello to all! This is my 1st thread on this site so be gentle! I've just dived head first into the depths of the 'overclocking' seas and have just upgraded my CPU cooler from a 'cheap' Akasa AK-859 cooler with adjustable speed control (which is not fitted) to a Zalmann CNPS 8000. The only question I have at this moment (as I have many) is that the copper pipes seem to be very, very close to my DIMM A1 module (about 2mm). Will this damage it?
Asus A8R-MVP MB
2x1gb 4-Layer V-Data PC3200 DDR SDRAM
Mercury EP-4500 500w (its a lie i tell ya!!) PSU
AMD Athlon 64 X2 3800+ (939) Manchester Core
Core Speed - 2400.7
Multipier - x10.0
Bus Spd - 240.1
HT Link - 480.2
Voltage - 1.40
Core 0 temp - 37
Core 1 temp - 38
Too much info?
I look forward to ANY replies!!
Cheers
), as has an Amber.
) pump as this one simply will not do. Oh and flow doesn't matter too much seeing as it's only in loop with a 120.1 Rad and CPU block.
