- 4 Nov 2004
- Norn' Iron'
my current system, e6300 (1.86ghz) to 2.8ghz
Starfall said:Anyone remember the OCUK "guaranteed overclock" AXIA TBirds?![]()
Don't worry you're not the only old timer, I started with a 80286/12. What you're describing sounds like an oscillator mod. As I remember the first boards, the CPU's were soldered on, later ones had a push in sockets. Where you had to work you way around the edge of the chip or bend the pins.Combat squirrel said:Ill take the performance crown for being SO OLD that I 1st thing I overclocked was a DX50 486 overdrive chip at 55, 60 wasn't stable, it was put in the 'overdrive socket' on the mainboard from what i can remember, original on-board chip was 486SX25 from memory, also remember having to solder stuff to up the speed, no bios or even jumper switches for overdrive back then
EDIT: No miketimbers and steve_pc also in the same era ! nice 1 lads ! noobs arnt they![]()
harris1986 said:Amd 3500+ (winchester) to 2.55ghz
silversurfer said:There was no dividers on those 486's but then some chips came at 50mhz anyway so I suppose it was ok.
What are you using 4 cores for![]()
