I probably shouldn't worry about this but being a bit of a control freak I was wondering what weight breeze blocks can support? At the initial stages of a conversion and the builder has said the steel beams are over 1 tonne in weight which seems a huge amount of weight to me?! There are 3 beams in total and they'll be connected in an I shape with the ends of the "I" being supported at each end (if that makes sense). The house is 20 year old with block and brick construction but will the block work support 1+ tonne?! The calcs have been done by a qualified surveyor so I assume he is aware of the load etc but it just seems a staggering amount of weight to add on but could well be the norm?
