- 7 Aug 2004
As title, would you RAID 0 them for some silly disk access speeds?
, 0+1 for fast speeds and system security
, or choose any of the other available RAID functions?
Jokester said:Well it would be complete pointless doing RAID 0 on a motherboard chipset controller as 2 alone will max out the bandwidth (even 2 of any modern drive will).
Jokester
Jokester
Jokester
mosfet said:Totally depends on the type of controller and how the controller is connected to the chipset. Most chipsets have at least 150MBps dedicated to each SATA channel, so connecting 4 fast drives isn't going to bottleneck.
matja said:raid 0, definately - you can never have enough linear transfer bandwidth.
How exactly the SATA chipset is wired to the system bus determines the maximum speed you'll see, most onboard these days use a single PCI-E lane so you should be good up to 250MB/s - shouldn't be a bottleneck for 4 drives considering there are certain inefficiencies and overheads regardling rotational latency and command queuing each time you add a drive.
If you have a Intel chipset with matrix RAID, you can carve up the disks into logical volumes with different RAID types, eg, RAID0 for your game installs, swap file, temp files etc, and RAID 0+1/5 for your important data. (but remember even RAID 1 or 5 is no substitute for good backups - they just prolong failure, not eliminate it)
I get between 220-300MB/s depending on which benchmark I run on my disks, which makes a vast different in loading times over a single disk.
Sharki said:JBOD For The Win lmao
messing ofc
yeah RAID 0+1 sounds good but arnt the raptors a tad noisey???
ive herd of people having enuff of the noise n ditching them
