Whats better than a Corsair H70 apart from custom watercooling?
22 May 2010
Minibotpc
As above really, i'm looking to play about with my cpu cooler and possibly replacing it with something better. Any suggestions?
I dont have room for a 240 rad though and the H80 wouldn't really be a upgrade considering it's cos the same size rad and pump?
The silver arrow looks godlike but the 140mm fans might not fit in my case since the 120mm rad only just fits...
the silver arrow is 163mm tall (although some people have measured theirs and found it to be up to 167mm tall). if you have over 170mm between the motherboard PCB and the side of your case then you will be fine
