Hey there people, I have a problem with my computer and need some help.
About 6 months ago I built a new computer using kit from Overclockers. The computer comprised of:
AMD Phenom II X4 Quad Core 955 Black edition 3.2 GHz
Corsair XMS 4 GB (2x2GB)
Gigabyte GA-890GPA-UDH3
Sapphire Radeon HD5830
OCZ ModXStream Pro 600W
I went out the other day and left it running, came back a bit later and the computer is off, my NAS, monitor and router were all still powered on and they run of the same plug extension block. I have never over clocked or altered anything on the rig, its all stock.
If I remove the power cable then replace and press the computer power button all the fans (CPU, case, GPU) turn a few revolutions and then stop, the power doesn’t latch on.
I have tried another power supply and that made no difference. I’m assuming it’s not the graphics card as it doesn’t even get that far into the boot sequence, it doesn’t even boot.
Any idea how I can diagnose this? Is it a motherboard or cpu?
