What's going on with Folding@Home?
Well I have put my rig back up to 4Ghz no point folding @ 3.6 hopefully i can have one of those weeks where it all goes without a single problem or is that asking too much :)
Not if i can help it
i'll need to see if i can get this system upto warp ten.
Well it will be a close one I think, so far this week
lol it was all going well till i started getting this
Launch directory: C:\SMP
Executable: C:\SMP\[email protected]
Arguments: -smp 7
[04:40:13] Configuring Folding@Home...
[04:42:06] - Ask before connecting: No
[04:42:06] - User name: marineiguana (Team 10)
[04:42:06] - User ID: 2F87442D3BC55B10
[04:42:06] - Machine ID: 1
[04:42:06]
[04:42:07] Loaded queue successfully.
[04:42:07]
[04:42:07] + Processing work unit
[04:42:07] Work type a0 not eligible for variable processors
[04:42:07] Core required: FahCore_a0.exe
[04:42:07] Core found.
[04:42:07] Working on queue slot 07 [May 11 04:42:07 UTC]
[04:42:07] + Working ...
[04:42:07]
[04:42:07] *------------------------------*
[04:42:07] Folding@Home Gromacs 3.3 Core
[04:42:07] Version 1.93 (July 23, 2008)
[04:42:07]
[04:42:07] Preparing to commence simulation
[04:42:07] - Ensuring status. Please wait.
[04:42:07] - Starting from initial work packet
[04:42:07]
[04:42:07] Project: 1797 (Run 7, Clone 131, Gen 0)
[04:42:07]
[04:42:07] Assembly optimizations on if available.
[04:42:07] Entering M.D.
[04:42:13] Rejecting checkpoint
[04:42:13] Protein: 41361
[04:42:13] Writing local files
[04:42:15] Extra SSE boost OK.
[04:42:15] Writing local files
[04:42:15] Completed 0 out of 500000 steps (0 percent)
[04:42:24] en 0)
[04:42:24]
[04:42:24] Entering M.D.
[04:42:30] Rejecting checkpoint
[04:42:31] Protein: 41361
[04:42:31] Writing local files
[04:42:32] Size of work/wudata_07.bed not what saved.
[04:42:32]
[04:42:32] Folding@home Core Shutdown: FILE_IO_ERROR
And
Trying to unzip core FahCore_b4.exe
[04:43:09] Decompressed FahCore_b4.exe (16564224 bytes) successfully
[04:43:14] + Core successfully engaged
[04:43:19]
[04:43:19] + Processing work unit
[04:43:19] Work type b4 not eligible for variable processors
[04:43:19] Core required: FahCore_b4.exe
[04:43:19] Core found.
[04:43:19] Working on queue slot 01 [May 11 04:43:19 UTC]
[04:43:19] + Working ...
[04:43:22] *********************** Log Started 11/May/2010 04:43:22 ***********************
[04:43:22] ************************** ProtoMol Folding@Home Core **************************
[04:43:22] Version: 23
[04:43:22] Type: 180
[04:43:22] Core: ProtoMol
[04:43:22] Website: http://folding.stanford.edu/
[04:43:22] Copyright: (c) 2009 Stanford University
[04:43:22] Author: Joseph Coffland <[email protected]>
[04:43:22] Args: -dir work/ -suffix 01 -checkpoint 15 -lifeline 5336 -version 629
[04:43:22] ************************************ Build *************************************
[04:43:22] Date: Mar 22 2010
[04:43:22] Time: 16:55:15
[04:43:22] Revision: 1789
[04:43:22] Compiler: Intel(R) C++ MSVC 1500 mode 1110
[04:43:22] Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[04:43:22] /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[04:43:22] Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[04:43:22] XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[04:43:22] Platform: Windows XP
[04:43:22] Bits: 32
[04:43:22] Mode: Release
[04:43:22] ************************************ System ************************************
[04:43:22] OS: Microsoft Windows Vista Ultimate
[04:43:22] CPU: Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
[04:43:22] CPU ID: GenuineIntel Family 6 Model 26 Stepping 5
[04:43:22] CPUs: 16 Logical, 1 Physical
[04:43:22] Memory: 3.00 GB
[04:43:22] Threads: Windows
[04:43:22] ********************************************************************************
[04:43:22] Project: 10038 (Run 1303, Clone 0, Gen 0)
[04:43:22] Reading tar file par_all27_prot_lipid.inp
[04:43:22] Reading tar file scpismQuartic.inp
[04:43:22] Reading tar file ww.pdb
[04:43:22] Reading tar file ww.psf
[04:43:23] Reading tar file protomol.conf
[04:43:23] Reading tar file core.xml
[04:43:23] Digital signatures verified
[04:43:23] Completed 0 out of 499375 steps (0%)
[04:45:18] Completed 5000 out of 499375 steps (1%)
Now is it me or are those two cores not SMP but uni-processor cores which are bloody annoying knew something would goes balls up :(
Gonna go browse the Folding forum for a answer.
Edit: Well this looks like it wont be fixed till later on today then :(
kasson wrote:We've tracked it down to a problem with some of the new AS logic introduced today. Hopefully we can fix it this afternoon; if not, we'll revert to the old code and then do another debugging session later.
So I'll just do these for a bit gives my CPU a break :p
Edit 2: Well those WU's just won't run and have now picked up proper one I can sleep in peace :D
Ah had one of those this morning. Thought the client had ballsed it up so I deleted the WU and queue, then got a proper SMP one.
Sorry f@h!
So anyone going to come up and help me up here? Guys? We are gonna get our butts kicked by Vietnam in a few weeks. :(
Ordering parts today :cool:
But I need to find somewhere to put my data from the server before I can do anything else. :(
Might ditch the on-board RAID until I can find a decent [cheap] NAS to back it up to.
Looks like its going to be another 2 weeks before I can get a gpu for this rig as I need to sort some cooling out, Carp case + stock cooling = toasty CPU
Would have been a bit better if measured up properly and hadnt order the CM Hyper 212 then stupidly cutting it up to make it fit.
You jinxed me :(
Some time tuesday night my whole system went belly up
ive now got to take it all apart to solve the mystery
looks as if my new gtx280 i got a couple months back is also cooked
as it boots to windows and then artifacts
After a prolonged absence I have returned :D
Prepare for the team to be buoyed by my awesomeness, surpassed only by those better than me.
I just bought an i7 920 and associated motherboard and RAM goodness :(
Expect it to be up and running in about a week! :D
Well thats my case completly empty now and had a good clean out.
My mobo has been switched for the newer version i bought from the MM months ago.
and cpu located ready to be installed into the case tommorow.
Just need to open up my psu and give it a good clean out and re route my WC loop as the pump is being moved to botoom of my case.
Drives are getting moved about and i will finally i think cut the top ready for my other radiator.so like sirusb i probably wont be able to turn my system to the ON position for about another week.
Hopefully with the new mobo i might even get a stable OC out of my Phenom ii 940 after having it for over a year without success so far.
Is anyone noticing bad output for the current SMP A3 WUs?
My i7 is only chucking out 10.7K PPD atm! :eek: I have seen this push 18K before now on 60xx WUs.
Current WU is 6013 R0:C198:G76. I really hope this isn't a sign something is wrong with my computer! :p
