- 26 Dec 2005
- Paisley
I prefer the picture on VGA, but you get tearning, which can be annoying.
Halo2 and ninja gaiden work perfectly on mineknowledge123 said:the only major problem i have with the official vga cable i have, is that backwards compatibility doesn't work, so you have to have a component cable to play original xbox games, the petition starts here!![]()
have you got the latest dashboard update?knowledge123 said:via vga? maybe it certain games thenhave you got the latest dashboard update?
Yes, 1360*768 VGA. I have the latest update and am running in PAL60 mode.knowledge123 said:via vga? maybe it certain games thenhave you got the latest dashboard update?
Nismo said:VGA is far superior to component in my experience for DVD's, and you also can get problems using component cables too.
Energize said:Dvds are encoded using the y/pb/pr colour format, not rgb so the component cables are what you are technically supposed to use as they give the colour truest to the original dvd video. Component video gives a greater range of colours than vga.
What sort of point is that then? VGA doesn't do anything apart from carry a signal. The 360 upscales to whatever res you are using when you use VGA. Therefore it's perfectly accurate to say the 360 upscales when using VGA.TALON1973 said:i said vga doesn't upscale. never mentioned whatever the xbox does. and component does work at 720p.
frogboy said:I love the way you're all arguing over which cable is better for DVD playback, yet you use a 360 to watch films..![]()
Get a standalone DVD player you fools!!
