Whats this problem memory Memory slot or another problem
21 Sep 2008
Recently bought a new Asus board and memory installed windows 7 last night all went fine got up today watched itv player then after restarted pc after updates went into windows fine but shut it down again and restarted and got this see pic never seen this ever any help would be great Thanks In Advance
[/url][/IMG]
Been running fine on windows 8.1 but i had to put win 7 on to use Dban. put it on today fine then after a couple of restarts it came with this problem. Will pull battery later but i hope the ssd hasnt gone.
I didnt remove battery but looks like issue was caused by ssd sata cable which is now replaced with a sata cable that isnt loose like the cables with the clips as there too loose
