Caporegime
- 7 Apr 2008
- Lorville - Hurston
Hi i was wondering if you can advice on a small issue.
Basically the toilet no longer flushes properly. When i push the handle down, all that happens is that the water trickles down. There is water in the tank but it never flushes properly.
Any advice? i try to keep pushing the lever down simultaneously and it use to work that way but not anymore.
Thanks
Thanks
