Wheel Alignment spec sheet - C43 Mercedes
25 Feb 2006
Sydney
Hi,
I'm hoping somebody can decipher this Wheel Alignment spec sheet I got at the weekend :
I noticed one of the front tyres on my 2017 C43 was wearing a little bit unevenly but the car was steering straight fine. I went in and got the alignment done, left the place then discovered that the car tracked to the left. I took the car back and let them know and before I knew and without asking permission then took the car for a drive. I wasn't impressed with that but within 5 minutes of them returning the car was done.
It now drives straight as expected but I'm wondering in the attached spec sheet looks normal ?
Thanks
Your front half toe looks to be well out on both sides and counter to each other but the correction they put in has taken it out of spec although it is more even now. How I read it the recommended value is +1.4mm with a tolerance of +/-0.6mm which the final value they have corrected to is out of spec. As a result toe that was in spec has been taken out of spec.
The same goes for the rear which is also out of spec. Does it matter? So long as you are happy with the straight line stability and the it tracks straight then it should be ok
Thanks for the reply Bear, judging from it I guess they did a poor job ?!
The car feels fine, I just don't want uneven tyre wear to cost me money. I'm going to contact them and see what they say.
Cheers
there is no tracking information on those reports though afaiks... just front/back axels - did you have something else ?
That's the only sheet they gave me
I just emailed them and will see what they say about the Out of Spec measurements, I'll report back with their reply
Cheers
Toe is your tracking is it not?
OK I had though toe was 'just' pairs of wheels pointing either straight ahead/parallel or usually slighltly together/toed-in at the front,
but not something about front versus back 'axels' pushing in same direction/aligned.
but, as you say report is consistant with others I can see on web eg
[ I need one doing myself so would have had a similar discussion if given just that report ]
The problem is once a tyre has started to wear unevenly, it won't correct itself if you fix the alignment. So it's hard to predict what the effect will be.
But I have had an issue in the past where an alignment place couldn't get a rusty bolt to move, so they basically bodged a workaround :/
That is Tracking
That is thrust Angle
Here was my email to the tyre shop :
__________________________________________________ __________________________________________________ ______________________________________________
Please find attached the spec sheet I was given once the ‘correction’ was made. If I am reading it correctly it appears that some parameters are out of spec :
FRONT AXLE
Half Toe : Spec is +1.4mm with 0.6mm Tolerance
The Final Value is +0.5mm – is this out of Spec ?
REAR AXLE
Total Toe : Spec is +1.9mm with 0.9mm Tolerance
The Final Value is +0.2 mm – is this out of Spec ?
Camber : Spec is -01.59 with 00.30 Tolerance
The Final Value LH -02.24 & RH -01.35 – is LH out of Spec ?
Please let me know if I am reading the sheet incorrectly ?
Here is their reply :
You are reading the print out correctly. However starting with the front, due to your camber being on the lower side of the factory specs
You would then lessen the toe to help with tyre life of the car. If your car was running the -1.5 degree of camber you would then run the toe @ 1-1.5 positive toe. Your vehicle also had some outside edge wear which is caused by the front originally being at 2.8mm total toe. Lowering this figure with the camber you have will help the tyre life. Which is what we have done.
As for the back. The camber is out on the left hand side this can cause a tracking problem as you made us aware of when you came in.
However with the factory adjustments on the car you are limited to the amount you can Adjust with the camber out by a full degree you would need an after market camber adjustment to bring this figure down.
XXX XXXXXXX, which is a European specialist can supply and fit this part for around $650.00. this would be an aftermarket centric bolt that should allow to get the camber on the left hand rear a lot lower. Unless there is a problem with the car which does not look to be the case as there is no damage to any arms underneath the car.
Any thoughts on their reply please ?
Thanks
Leave it dude.
The front toe was out, they fixed it, the rear camber being out doesn't affect front tyre wear.
It drives straight, dont spend big money on camber bolts you dont need.
