Wheel nuts too tight!
Zip said:
Put the thing that you use to undo the wheel nuts on the wheel nut. Then stand on it and bounce a few times and the wheel nut will come off nicely :)
Best way to snap something, either your bar or your wheel nuts, imo.
Get some penetrating oil, some heat and a big breaker bar on it - else take it to a local garage and ask them to get their impact gun on them.
Blimey, I've really started something here haven't I? ;)
I'm taking the car to a mechanic friend of mine to see what the rattle is (nope, not the same guy that did the bolts up too tight :p). Never had this problem before as I've always used a reputable tyre place I know or done it myself.
I have busted a T bar wrench, with my hands when trying to undo the nuts on my BM once when done by a gun!
I have done the bouncing thing on a BMW standard one before, worked fine. I also did it on the volvo a few times. However to do that i jumped from about a meter up and down onto the end, snapped them out fine about 8 times :D (Although the volvo standard bar did start to bend a tad :p
