When booting not picking up hard drive?
21 Jun 2005
Last night I shut down, I bounce my leg a lot and knocked the power as it was shutting down, didn't think anything off it as I've done this before. Turn on the PC today and it can't find my HDD which has the OS on it but it can see the other 3 sata connections (2xHDD 1xBluray)
I've tried swapping the cables around, leaving only the OS one in, tried using the other cables with it, I've tried resetting the CMOS nothing I do is making it work and I'm really unsure what to do next.
Any ideas?
It's a crucial M4 HDD and Asus Rampage Extream IV
Thanks
Try turning it on with no drives plugged in and go into BIOS, shutdown, plug in just your boot drive and go back into BIOS and set the boot drive order, save and exit.
When I've been adding/removing drives this is sometimes the only way I can get my boot drive back to first boot drive!
Hi mate thanks for that, still not even seeing the hard drive in bios when doing that :( thanks for the suggestion though mate
http://forum.crucial.com/t5/Solid-S...quot-disappear-quot-from-my-system/ta-p/65215
The power cycle didn't work. I tried it several times.
But I found another way. I left the SSD overnight powered in my PC without the data connector. This morning I attached the data connector and pushed reset. This worked because the SSD needed some time to recover while the power cycle method breaks the recover process and lets it start again from the beginning every time the SSD is unpowered. During the reset the power is not interrupted and the SSD can be detected again afterwards.
Just an update to say thanks vashiro, thank you very much.
I left the power in the HD only while I was playing games ( built another HD ) for 6 hours, then plugged in the sata cable and hit restart, now all working.
Thanks very much.
