Mention "auto rotation" and see what he says thenStiff_Cookie said:Source: Dad is a flight engineer on the MH-53J Pavelow and has been for about 20 years.
![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
Autorotations are used in helicopters to perform power off landings from altitude in the event of an engine failure. During an autorotation, the main rotor is not driven by a power plant but by air flowing through the rotor disc bottom-up (imagine a windmill) while the aircraft is descending rapidly. The power required to keep the rotor spinning is obtained from the aircraft's potential and kinetic energy. An important contributing factor is the rotor's inertia.
Autorotation is also used in autogyro aircraft as the main means of achieving lift during normal operation. See autogyro for more information.
Kaed said:From what I remember from playing ummm some Apache flight simulator on my amiga many moons ago - it mentioned autorotation
http://en.wikipedia.org/wiki/Autorotation
andy8271 said:well this thread has doubled my fear of helicopters![]()
Guybrush said:As someone with a degree in aerospace engineering who works for one of the aerospace companies making V22 Osprey tiltrotor, Westland Lynx and EH101 components and an RC helicopter pilot for 10 years+, I say that the helicopter has no trouble landing if the engine stops, either hovering or with forward velocity![]()
To enter the autorotation, the pilot lowers collective all the way down, simultaneously adding right pedal (in American helicopters - the rest of the world's helicopter blades turn in the opposite direction, so you would add left pedal in them).
Raymond Lin said:It can hover without engines??????????![]()
Hmmm, do you know the helicopter can lands anywhere?LeperousDust said:Right here your totally random question for the day:
When a helicopter runs out of fuel, does it:
a) drop like a rock
b) descend slowishly
Answers on a postcard, and can i have credible sources backing up which ever answer you think is correct.
I'm having a little argument with someone, and would just like someone to back me up, and some proof.
Guybrush said:No, I never said that did I - it can land from a hover if the engine stops.
1pudding1 said:An autorotating propellor has the same drag as a flat plate of the same diameter, so the drag that causes just slows the descent.
