Well let's just put it this way. My 4 year old E6300 @ 3.15ghz has yet to be the limiting factor in any game I've played![]()
you must game at 800x600 res on 17" screen. LOL
i game at 1920x1080 on a 24" screen & my Q6600 must be OC @ 3.6 in order to play CPU intensive games smoothly,games like the new need for speed & black ops.
That's probably because you are using a 5770. If you look at how much cpu load you are running you will probably find that you aren't anywhere near 100% on all 4 cores at 3.6ghz. Obviously at 2.4ghz stock it would be a limiting factor but beyond 3ghz on a reasonably modern cpu, the limiting factor is the gpu
Most modern flight sims will send a 3ghz cpu crying home to its momma.Thats probably because you dont play flight simsMost modern flight sims will send a 3ghz cpu crying home to its momma.
