Well there no mid range cards on ocuk and other sites to be had at all.Well you can loads about
What you really should have said was I dont want to pay the silly prices
OCUK has 6700XT's in stock...Well there no mid range cards on ocuk and other sites to be had at all.
I thought that was a high end card going from the priceOCUK has 6700XT's in stock...
you listen to most people on here a rx6700xt is mid range
but I know what you meen
Get a Series X
IMO 6700XT is the very top mid-range card, but nether AMD or intel are releasing traditional mid-range or low range this generation. the cost of everything is so high it's just not worth it for them.I thought that was a high end card going from the price![]()
