Where can i get these....
5 Jun 2005
Southampton
i need a few of them, they kind of pinch in and lock
Anyone who sells them would probably be a competitor so I don't think I could give you a name even if I knew one. However what you are looking for is push-pins I think, I have in the past used even garden twine to hold on a graphics card heatsink - still works fine but it isn't the hottest running card to begin with. Insulated wire (again you might find it for gardening) would perhaps do at a push.
I dont know where to get the push pins specifically, but have you thought about simply bolting the fan down to the card, and using a couple of those little rubber grommets as vibration dampners?
Could even go as far as using butterly nuts (wing nuts) to tighten up, giving you more control on the pressure you apply.
i was unsure if the metal contact would be an issue?
