Of what, bf2 or xp?squiffy said:Fresh install![]()
I might give that a try. Rebooting seems to 'reset' it, and it doesn't come back until i play the game for a while.Try downloading XP-antispy, tick the 'clear pagefile at shutdown' box, reboot and see what happens.
Long shot and it prolly wont work but its worth a try if nothing else.
I don't need 4gb of ram. Its not using what i've got, thats the point.Cyber-Mav said:do what i did and get 4 gigs of ram. you will get no problems with it.![]()
Bingo. There you have it. I'm sure thats whats going on. I'll have to contact ea and find out why, and hope the 1.4 patch fixes it. Thanks for the definitions.Tetras said:Couple of google definitions for you![]()
# A programming term describing the losing of memory. This happens when the program allocates some memory but fails to return it to the system. Excessive memory leaks can lead to program failure after a sufficiently long period of time.
# Memory leaks are often thought of as failures to release unused memory by a computer program. Strictly speaking, it is just unneccesary memory consumption. A memory leak occurs when the program loses the ability to free the memory. A memory leak diminishes the performance of the computer, as it becomes unable to use all its available memory.
http://en.wikipedia.org/wiki/Memory_leak
Online games are particularly suspectible, a lot of mmos have that problem.
Tried setting a 3gb pagefile, yes, i have tried a different drive but i'll try again as i can't remember if i was having this issue with the pagefile on the other drive. Haven't tried turning folding off as i see no reason to suspect it.Did you get round to trying the larger fixed swapfile btw? And I'm guessing you've tried turning folding off? Drive/swapfile fragmented?
Tetras said:It is at least one of the reasons why people refer to BF2 as still being in beta, memory leaks tend to be sloppy or unfinished code imo.
Absolutely. It has had a memory leak in one of the server versions that caused constant server crashes and it took weeks to fix.Tetras said:It is at least one of the reasons why people refer to BF2 as still being in beta, memory leaks tend to be sloppy or unfinished code imo.
Not a chance, they haven't been working on that for very long at all, there is no way its near finished and i doubt it will be finished when its released.SameSuspect said:ridiculous isnt it. Well 2142 is in free beta at the minute, hopefully it wont be as dodgy when its released. hopefully
