I want to buy a 1TB internal SATA drive. All the ones on OcUK seem to be 4/5 star so any suggestions would be great!
Oh and I need a SATA cable, does it matter which one or are they all the more or less the same?
Thanks
I use something similar though one of the connectors is right angled - helps to make things look neater. Get one with a latch connector to enable a secure connection.
