Which 1TB SSD for secondary gaming drive...
So would I.
I'd go for mx500 1tb out of them 2 drives
Thanks for the replies.
I did go with the MX500 in the end, I have a few of them in different computers but hard to believe as old as it is, it is still a great drive.
Does the QLC mem offer marginal longevity over TLC or is it that marginal it is not relevant, especially if using as a secondary gaming drive?
Game sizes are just becoming bonkers nowadays though, even a 1TB drive does not allow for much.
No problem mate I had mx drives and they're good drives I just bought a wd blue tb as it was slightly cheaper at the time for game storage as for tlc and qlc not sure mate
I still have an old Crucial MX200 drive that I bought when the Core i7 4790k first came out... It's had quite a bit of use for around 6 years now and still reports 96% drive life remaining.
QLC is worse than TLC for longevity, you can tell that from the difference in warranties and write durability. For example the 1TB 860 QVO (QLC) has 3 year warranty with 360TBW (per year), whereas the 1TB 860 EVO which is TLC has 5 years warranty and 600 TWB per year. Doubt you will have any problem at all or notice any difference between QLC and TLC on a game drive though.
You sure those tbw figures are per year? Flash endurance is rated as either PE cycles, Drive writes per day or total cumulative tbw.
it's nice to have the warrenty, but those TBW figures are hard to reach.
if you tried to write 600TB over 5 years:
600TB or 600,000GB/5(years)*365=328GB per day of writes.
Are you downloading a lot of data and then moving it? or just installing/uninstalling some games/apps?
