- 26 Aug 2004
- Manchester
As title, I have £300 to spend on a 24" monitor...
Back when I got my 2407 there were only a couple or 24 inchers to choose from, but now there's loads of choice, so hopefully you can help me narrow it down!
What I'm looking for:
Widescreen, obviously.
Black preferred (but by no means a deal breaker).
Must have a DVI input, other inputs not really important (although HDMI may be useful at some point in the future).
VESA mount compatible.
Good viewing angles.
Not the OcUK Value.
I was looking at the Samsung 245B, but apparantly it has a TN panel? As it's going to be used as a TV (secondary to PC use) a TN panel isn't an option.
So what should I be looking at?
Not the OcUK Value.
