Which 24" Monitor
11 Apr 2008
I will be using it for normal stuff like internet, and gaming. Dont really watch movies on my PC.
Which one out of these would be the best or is there any others around thoes prices?
Acer G24
1920x1200 Resolution
50,000:1 Contrast Ratio
2ms Response Time
400 cd/m2 Brightness
http://www.overclockers.co.uk/showp... Widescreen Gaming LCD Monitor - Orange/Black
BenQ G2400W
1000:1 Contrast Ratio
5ms Response Time
250 cd/m2 Brightness
http://www.overclockers.co.uk/showproduct.php?prodid=MO-024-BQ&groupid=703&catid=17&subcat=510&name=BenQ%20G2400W%2024"%20Widescreen%20HDMI/HDCP%20LCD%20HD%20Monitor%20-%20Black
BenQ V2400W
4000:1 Contrast Ratio
2ms Response Time
http://www.overclockers.co.uk/showp...creen HDMI/HDCP LCD HD Monitor - Black/Silver
Dell S2409W
1920x1080 Resolution
5ms Response Time
300 cd/m2 Brightness
http://www.overclockers.co.uk/showp...9W 24" Widescreen True HD LCD Monitor - Black
Samsung SM-2443BW
20,000:1 Contrast Ratio
5ms Response Time
http://www.overclockers.co.uk/showp... SM-2443BW 24" Widescreen LCD Monitor - Black
Samsung SM-2493HM
10,000:1 Contrast Ratio
5ms Response Time
http://www.overclockers.co.uk/showp... SM-2493HM 24" Widescreen LCD Monitor - Black
HP LP2275W
1680x1050 Resolution
6ms G2G Response Time
http://www.tftcentral.co.uk/reviews/hp_lp2275w.htm
These 2 are not out yet, but I am thinking of getting 1 of them.
Samsung SM-2343BW
2048x1152 Resolution
5ms Response Time
http://www.overclockers.co.uk/showp... SM-2343BW 23" Widescreen LCD Monitor - Black
Dell SP2309W
2048 x 1152 Resolution
2ms Response Time
http://www.tftcentral.co.uk/news_archive/15.htm#dell_sp2309w
ewww ...don't go with 2048X1152, get the SM-2493HM.
Viewing angles aren't the best but what can you expect from a 24" TN panel?
if you can use the 16:9 ratio and can handle the 2048X1152 the i would go for it.
Here is my PC's spec.
Antec Nine Hundred Ultimate Gaming Case
Intel Core 2 Quad Q9550 overclocked to 3.4GHz
Arctic Cooling Freezer 7 Pro CPU Cooler
Asus P5Q Deluxe Motherboard
4GB DDR2 Ram
Nvidia Geforce GTX 280
500GB HDD
Thermaltake High Performance 850W PSU
Microsoft Windows Vista Home Premium 64-Bit
usama - i thought you'd already purchased the 2409 and your mate had the benq? was it not you that did the side by side comparison with transformers?
Viewing angles dont really matter to me, because I am only going to look straight at it. :)
I thought the same, but in dark game scenes you'd be surprised how much difference a small change in vertical height will make. If you sit close to your screen, you may see significant differences between the top and bottom of the screen, with a TN panel.
Just something to bear in mind. I went for the Iiyama 2403WS, which I've been pretty happy with. My next monitor won't be a TN panel though.
When was the last time you saw a PC game that supported the strange resolution? I'm sure they'll come in the future, but for now any monitor with that res will be a liability and nothing else.
Please check my sig you will find that i have the Samsung 2443BW 1920X1200.
I was only saying that more TFT are coming out at that res.
