Which is a better external drive, the LaCie Black 500GB USB2.0 External Hard Drive or Western Digital Elements 500GB?
Thanks
WD Elements
Dimensions (WxDxH): 12.5 cm x 20.4 cm x 3.6 cm
Weight: 1 kg
Capacity: 500 GB
Interface Type: Hi-Speed USB
Data Transfer Rate: 480 Mbps
Average Seek Time: 8.9 ms
Spindle Speed: 7200 rpm
Lacie
Hi-Speed USB 2.0: up to 480Mbits/s (60MB/s)
Hi-Speed USB 2.0: up to 34MB/s
Cache: 16MB
Fan: fan-free operation
Software: LaCie '1-Click' Backup Software (Windows XP/2000, Mac OS 10.x), Silverkeeper backup software (Mac OS 9 & 10.x), Silverlining Pro Utilities (Mac OS 9)
Size: 1.6 x 3.3 x 5.5 in. / 40 x 85 x 140 mm (WxHxD)
Weight: 1.4 lbs / 650 g
This is also around the same price
Seagate 500GB Barracuda eSATA 7200rpm 16MB cache External Hard Drive with PCI eSATA Card
"the eSATA External Hard Drive, PCI card and cable work together to achieve five times faster transfer speeds than either USB or FireWire 400 connections."
However -
Drive Transfer Rate
300 MBps (external)
Spindle Speed
7200 rpm
Is this eSATA thing a marketing stunt?
Thanks
WD Elements
Weight: 1 kg
Capacity: 500 GB
Lacie
Cache: 16MB
However -
Drive Transfer Rate
300 MBps (external)
Spindle Speed
7200 rpm
